How do I replace my headlight switch?
So.. How do I do it? Does it involve removing the entire dash face plate? Any help would help... On the 94
Remove 2 screws holding in the cup holder and remove it. Remove 2 screws holding in the ashtray and remove it. I usually start above the radio when removing the dash bezel. You can pull out on the dash bezel pretty easy above the radio (for me anyway). The bezel has clips that hold it into the dash. Pull the bezel back firmly, but don't yank on it. Tilt your steering column all the way down. Be sure to unhook the wire going to your 12v accessory/cigarette lighter plug. Just take ur time, it's pretty easy to get out. After you remove the dash bezel, you will have access to the switch. I believe there are 2 or 3 screw that hold it in also.
Three screws hold the switch in the dash. After you remove them and the switch you can unplug it. Then you remove the knob and face plate, and install them on your new switch.
Thanks guys!
Very timely info as my switch is bad, too. I picked one up at local auto parts store and the switch aslo came with a replacment connector.
How often does the OEM connector burn up? |
I don't know, but my switch does not have a plug on the back. It is just female spade connectors. Probably previous owner crap. But it is good to know they come with a spare plug, since I would like to change mine out.
Originally Posted by Fueling around
(Post 1818656)
Originally Posted by TIMMY22
(Post 1818883)
The wire harness beneath the drivers battery tray gets a lot of corrosion in the north country. This happened to mine and melted my plug too. I had to fix the rotted wires, then fix the plug.
Originally Posted by JSPulliam21
(Post 1818880)
claw hammer
(Post 1818939)
Are you talking the headlamp wiring or the switch wiring inside the cab?
I just did a switch last night, If memory is correct this is the 3rd or 4th one.
I prefer to leave each connection loose, with there own terminal. the factory harness plug melts out, and your stuck re doing that whole mess each time. If it has gone out , take a few minutes, look at what is going on, it will most likely go out again. |
(Post 1820441)
headlight harness under battery causing melted connections at the headlight switch.
Originally Posted by smokeyram
(Post 1821119)
