Heated seat
on my 2001 Dodge ram 3500 the driver side heated seat wont work when you push the switch it just blinks any suggestions ?
The factory service manual will tell you the problem.
How many blinks and what is the sequence? Usually the element in the seat goes out, the wiring breaks loose at the entry point and then opens the circuit. Post up the blink sequence and I will look it up if I have a chance today..... |
Thanks it is so **** cold out side now suppose to be warm tomorrow I will go look then Thank you
If it flashes on high and low, the heater element is shorted.
If it flashes on high and stays off on low, the element is open circuit. If it's off on high and flashing on low, the temp sensor value is out of range. |
Thanks, Ron. I didn't have a chance to reply to her.
Thanks guy's I had a chance to get to the shop today and checked the truck out it flashes on the low side (temp sensor value out of range ) where do I go from here. Thanks
Relay maybe? I'll check the FSM tonite if nobody else can...
If it were a relay, none of it would work. It said temp sensor and I believe that is part of the heater panel itself.
Heater panel ? the one for the truck cab heat or is there a seperate one for the seat and where would it be located
I agree, I looked thru my FSM and the ohmage is quite wide between the high and low side, something like 33 ohms hi and 510 ohms on the low side. This can be checked with a multimeter between the two outer connectors on the back of the switch, bottom row. The allowable range is +-5 ohms.
The switches are the same so you could just use the passenger side til you get another and get thru the cold snap.[guitar] |
4 Attachment(s)
Originally Posted by Racheljeanwalke
(Post 3262738)
From the FSM. Attachment 44175 Attachment 44176 Attachment 44177 Attachment 44178 |
Thank you so much
(Post 3262738)
Unfortunately the heater element isn't sold separately. The Mopar parts database I have shows it as part of the seat cover only. |
well I went and ordered a seat cover with heat and got about a mile away and blew the rear end how exciting
(Post 3262907)
