Heat/Ac Position switch not working?
Old Mar 2, 2007 | 07:48 AM
dzlfarmboy's Avatar
Question Heat/Ac Position switch not working?
I have an 2001 and all of a sudden the only place the air blows is on the defrost position on the winshield, i can turn it to the floor position, upperbody positioin, or even AC and it still blows up through the defrost vents. Has anybody ever had a problem like this before? Any input would help thanks Brett
Old Mar 2, 2007 | 08:32 AM
patdaly's Avatar
Vacuum leak or Heater control module the likely culprits.
Old Mar 2, 2007 | 08:59 AM
dzlfarmboy's Avatar
So you think it's either vacum or electrical i have no idea how what that switch works off of
Old Mar 2, 2007 | 12:20 PM
patdaly's Avatar
Do a search on my thread entitled 97 CTD hard starting. There is a link buried in that thread that gives a 2001 service manual .PDF. It is a great big friggin file, but well worth the wait to D/L.
It should answer any questions you have and help troubleshoot your actual problem.
Old Mar 2, 2007 | 11:07 PM
fschiola's Avatar
Check your vacuum lines from the pump up. The default setting when no vacuum is present is defroster only.
Old Mar 2, 2007 | 11:30 PM
torquefan's Avatar
Exactly. Start under the hood. Vacuum starts at the vacuum pump, reduces down to a thin plastic vac line, and enters the cab in the same place where the heater hoses enter the firewall. Give it a good inspection, also wouldn't hurt to use a gauge to measure system vacuum. Should be over 16 inches vacuum at idle if no leaks.
Old Mar 2, 2007 | 11:34 PM
CSAGrey1's Avatar
there is a t-fitting for vacume up on your firewall if it is like mine. Check it. I bet you 4x4 doesnt work either does it?
Old Mar 3, 2007 | 11:47 AM
dzlfarmboy's Avatar
Ok thanks guys i'l check out the things you mentioned
Old Mar 3, 2007 | 02:25 PM
SIXSLUG's Avatar
If its the switch control panel and you don't have heated mirrors contact me for a replacement. I have a nearly new one off my truck. Also pull the switch panel and check the vacuum plug on the back, sometimes there's white grease build-up in the holes. I used a welding tip cleaner for this, a very hand tool. Kurt
Sleigher
May 4, 2017 02:12 PM
thomas79
Dec 15, 2012 01:25 PM
bkrukow
Apr 29, 2011 06:42 PM
gmh
Nov 28, 2010 07:47 PM
dodge350c
Jan 24, 2009 07:57 PM
