-   2nd Gen. Dodge Ram - No Drivetrain (https://www.dieseltruckresource.com/forums/2nd-gen-dodge-ram-no-drivetrain-90/)
-   -   headlight problem! (https://www.dieseltruckresource.com/forums/2nd-gen-dodge-ram-no-drivetrain-90/headlight-problem-312482/)
mtdoragary Jun 6, 2013 05:53 PM
headlight problem!
OK, never had this problem in the last 55 years of driving:
Low bemas are dim in one position and bright in the other. High beams never come on. High beam indicator lights regardless of whether of switched to high or to low. Anyone ver had THIS problem???
Diesel Dave2 Jun 6, 2013 06:01 PM
By some chance...do you have a Canadian truck with daytime running lights??
mtdoragary Jun 6, 2013 08:13 PM
Nope; US truck, no DDL's.
patdaly Jun 7, 2013 08:10 AM
Multifunction switch is a common culprit......... Take the cover off and give it a look.
mtdoragary Jun 7, 2013 08:31 AM
Cover is off. What should I look for?
Diesel Dave2 Jun 7, 2013 11:51 AM
Check the switch for any burnt smell...It's common for these headlight switchs to short out...:o..
mtdoragary Jun 7, 2013 12:22 PM
No burnt smell....
Where are grounds that typically cause headlight problems..?
cneuman Jun 8, 2013 02:49 PM
The headlight switch is junk and cannot handle the current through it. Worse if you tow. Probably needs replacement and recommend a relay harness to take headlight current off the switch. I had to replace my 97 twice before I got a relay harness.
joem Jun 8, 2013 10:43 PM
I put this in my 2500, fixed the issue- takes the trailer running lamp's off the headlight switch. The more lights on your trailer the quicker your headlight switch dies
http://dodgeram.info/tsb/recalls/819.htm
olddodgetrucks Jun 9, 2013 06:14 AM
had a truck that did that,someone put the wrong # headlight bulb,,glad I noticed before I started to change switches.
mtdoragary Jun 9, 2013 06:27 AM
hmmmmmm
patdaly Jun 9, 2013 11:59 AM
You didn't just put light bulbs in did you?
mtdoragary Jun 9, 2013 02:13 PM
No, but I bought the truck not long ago and just noticed the problem. Never drove it at night. What lamps should they have?
RottnRam Jun 9, 2013 06:32 PM
I replaced my stock bulbs with PIAA 9004 bulbs. They are improvement over stock and I think they come with a lifetime warranty.
mtdoragary Jun 9, 2013 06:39 PM
Thanks for the heads-up!
