GM wheel cylinders put in today........day and night!!!!!
#61
?? Are the Self Adjusters not working because of the cylinder change or did they not work before?
Mine are working but I still adjust them manually, when I back-up I guess I don't apply the service brakes hard enough to actuate them.
Do the 30mm cylinders affect the RWAL’s operation?
Thanks.
Jim
#62
You've probably got some other problem if its pulling. Take the rear drums off, clean and adjust the rear shoes and see if that helps. Maybe you've got a wheel cylinder or axle seal leaking back there.
John
#64
I consider myself very mechanically able and have never been able to figure out why some Dodge self adjusters don't work even after cleaning, lubing and close inspection.
The correct way to self adjust the shoes is to go in reverse, preferably on a paved surface and apply the brakes till you come to a complete stop. Speed or the amount of pressure on the brakes make no difference, most important thing is a complete stop. Some folks like to self adjust using the emergency brake as then the front brakes don't come into play.
#66
#68
Easiest method is to push the the clip in that keeps the starwheel from spinning backwards and then just loosen the starwheel with a screw driver. Get em loose enough and the drums usually come right off with a good whack or two.
#69
Easiest way is to jack both rears off the ground, support well, remove both wheels and replace one lug nut losely. Start it up put it a forward gear with a little throttle then slam on the brakes. Do it in reverse if necessary. You will hear it very well when the drum breaks lose.
Usually no need to back off the star wheel unless your brakes are adjusted too tight or the drums are severely worn.
#71
When I upgraded the wheel cylinders in mu old '92 W250 I also upgraded the shoes from the 2.5" wide ones to the 3" wide ones. For those with 3/4 ton trucks you may want to check how wide the ones you have are and upgrade the the bigger ones.
Those two things made a HUGE difference in my old truck. Had a camper in the box and was pulling a trailer with a my jeep on it and the trailer brakes failed. Had no problems brining the load down the mountain into Radium BC.
Still had to manually adjust the rear every couple of months though.....
#73
I did my 96 4X4 this weekend too. Good thing I was reading this thread as I had to use Infidel's suggestion on braking the rear drums loose. Also removed the front calipers and lubed the bolt and sleeve that let the calipers slide. As I was doing all this I also flushed the brake fluid and gravity bled the whole system. Brakes work better than ever. I know the bigger wheel cyl. helped but I think the gravity bleeding did a better job of bleeding. Now on to the next task, leaking trans cooling line.
#74
