Fumoto oil valves - possible clearance issues?
Has anyone used a fumoto oil valve? Is there a clearance issue here? Are there any other products that will make it easier to change my truck oil in the driveway?
I have had one on my 97 4x4 for about 3 years with no problems. It only hangs down about an inch.
I have one as well!! excellent product, makes it easy to take oil samples
If they had big time clearance issues we would have read bad things about them on here I think... but never the less, if you are concerned about clearance, another one to check out is the EZ change drain plug and tube... more expensive, but it makes oil changes simple too. I've had one for about 10 years and its worked great. The tube lets you control the oil drainage pretty well. Geno's carries them, you can check it out there.
My question for years has been what's wrong with the factory drain plug?
For me simple is always better, never had a problem with the regular 'ol screw plugs on any engine. |
Clearance is what worries me too. I'm worried I'd rip it off and dump all the oil. Course I've got an oil pressure alert on the Edge, so I probably wouldn't do any damage, but I'd still be up the creek...
Fumoto drain plug.
Unless you rock crawl,I don't see how you'd ever hit that part of the truck anyway. It functions way better than the stock plug in that it is a controlled flow,not the "deluge,all or nothing" feature of the stock plug. It's the best $23.00 if put into the truck. I'm using the one without the nipple. There's a tech who posts here occassionally who's seriously wheeled all over the Southwest without an issue.
Originally Posted by infidel
(Post 2564738)
i have the fumoto and it has been great. as said above - unless you are rock crawling, you will have no issues with clearance. if you are worried about bouncing rocks and low flying debris - don't be, it is very well protected by the front diff and axle.
as an added precaution - when i installed mine, i screwed and unscrewed it tight a couple times rotating the starting point each time until the lever ran front-to-back as opposed to side-to-side. i would stay away from the EZ drain. he reason is because i had a friend using one and it uses a spring-loaded mechanism to open the plug and allow it to flow. well one day while performing an oil change something failed and the spring popped out (along with another hefty piece of brass) and into the oil pan. he tried everything under the sun to try and pull it out to no avail, and magnets did not work (it's brass). he then tried to drop the pan but a cross member got in the way. he had to have it towed from his driveway into cummins dealer and the motor had to be lifted up away from the frame to drop the pan enough to have access to get the pieces out. that being said - i know there are many many guys using the EZ drain without any problems whatsoever. |
I don't rock crawl. However I have high centered in rough conditions. Therefore it flush stock for me......I would have sheared it off had it stuck down.
the "deluge,all or nothing" feature of the stock plug In fact I rarely totally remove the plug, just a couple of turns is enough. |
The 6.7 oil change experience is an unforgettable one to be sure. I had an EZ change one on my old truck and have since put one on the 6.7. That sooty oil WILL NOT come out of clothes!!!!
