Fuel tank leaking(removing the bed)
Bill,
My truck had steel lines coming out of the sender. Is that one in the picture an updated part or one from a newer truck? The steel lines on mine rusted away so the plastic seems like it's a much smarter idea.
John
John
Well I found the leak.
Apparently something hit the tank about mid way up in the front and put a gash in the tank. I cleaned it real good and put some JB weld in the gash and around the area. So will see if this works.
The inside sealers work excellent for rusted metal tanks. The way I've used the inner sealer is to chain the tank to a rear tractor tire, tractor jacked off the ground. Put a couple of handfuls of gravel or nuts in the tank and let the tractor idle in low gear for an hour or so. Cleans the tank of rust great.
Then add the sealer and let it idle again.
Bill,
I love your simplicity of engineering.
I would have never thought of putting a tank on a tractor tire and filling it with nuts to remove rust.
MAKES COMPLETE SENSE THOUGH!!
I've heard of suspending the fuel tank from bungee cords between two trees, adding a bunch of pea gravel, and shaking it around for a while but Bill's idea takes it to a new level.
John
John
In my mind it depends on how rusty the bed mounts are. If they are nice and rotted the chances of stripping, snapping, cross threading, etc, the body mount bolts increases quite a bit. Sometimes it's just inevitable, regardless of how much liquid wrench you use! A truck as new as an 06 probably wouldn't have that problem, but 2nd gens are getting a bit older so it's something to take into consideration.
dodgerdog
02-23-2009 10:54 AM
PRO-NRA
16
04-01-2008 12:13 PM
