Fuel gauge quit
That about sums it up. No workey. Where should I look first? I understand it's a fairly common problem, so I thought I'd ask those that have been there and done that[director] Thanks!
I'd look at the sending unit in the tank.....very common to go bad
Most likely the sending unit in the tank. Nine times out of ten that is the problem.
Thanks for the replies--I'll look there first!
Hi G1625S,
When you say the fuel gauge doesn't work, do you mean the needle isn't registering at all? Or do you mean the needle isn't registering the true contents of the tank? If it is the latter, the sending unit in the tank is probably to blame. In that case, it is common for the gauge to show about half to quarter tankful when it is actually empty. What are your symptoms? |
Originally Posted by littlebuddie
(Post 2540527)
Hi G1625S,
I've got a question on this subject. Couple years ago mine did almost the same thing and when i pulled the unit out the float that was supposed to be on it had disappered. Anybody else ever have this happen?
G1625S, I don't know a whole lot about this but it does sound like a tank sending unit problem. You may have to pull the tank and check the ohms at the sending unit or something else may be very apparent to you once you look inside the unit. Hang on, someone with more to offer will chime in. Meanwhile since I know this sort of thing comes up often on the forum, try a search for 'fuel gauge' or 'sending unit'. A lot comes up on the subject.
Take the unit out of the tank and inspect. THEN get back to us. Simple as that.
I'll be pulling the tank next week. Just filled up[duhhh] I'll try and snap some pics of what I find and post them up.
Check out this thread also:
https://www.dieseltruckresource.com/...highlight=ohms |
Apparently some of the components used on the older sending units weren't compatible with diesel fuel.
The new ones are and last. Sending unit is about $60 at the dealer. Don't let them tell you it isn't available separately and you have to buy the entire $300 module, it is definitely available separately. |
(Post 2540527)
Hi G1625S,
Originally Posted by powersmoke
(Post 2542086)
What would be the problem if the fuel guage only shows full all the time?
I'd start by grounding the fuel sender wire near the tank if the gauge goes to full It's probably the sender If it doesn't It is possibly the wire or under the dash....gauge etc. start by isolating the problem before you go after the sender
