Fuel gauge not working
Can be topped off and the gauge does not move. Where do I start. This is on my 2001.
Kip |
Common problem on the 2nd Gen trucks, most likely the fuel sender. Around $75 to replace. Fixed my problem anyway.
mishkaya |
any way to test it to make sure that is what it is? where is it? Probably in the tank right???
is it dealer only or do the parts houses have it?
yup you gotta drop the tank for it. idk go to your local parts place and ask them for a sending unit for a 2001 dodge ram 2500 diesel.
JARHEAD
You can test the resistance of the sending unit, it should be 20/200 Ohms. I can't remember which one is full and which one is empty however. mishkaya |
What parts house did you get yours at? I am batting a .000 right now. The dealers are telling me I can only buy the pump unit as a whole. My pump is not in the tank of course.
Search the site for a fix on this. I did it about 3 mnths ago. Raised the bed, pulled the unit out, performed the fix and it has worked ever since. It cost about .$25 for the push nut (washer) at ace hardware and is really easy to do.
Originally Posted by JARHEAD
(Post 1973380)
mishkaya |
Originally Posted by jknowles4
(Post 1975904)
mishkaya |
You can still get it through the dealer, so your dealers parts guy is full of it.
My fuel gauge hasn't worked for over 2 years.
I always go by the trip odometer, so it hasn't been of significance to me. I also have no access to any kind of facilities to repair this, other than taking it to the local dealer that I can't afford. jh |
| All times are GMT -5. The time now is 03:34 AM. |
