front end "loose"
front end "loose"
I've got a loose or clunking feeling in my front end, especially when I step on the brakes going down hill. I feel it through the steering wheel. The track bar shows no movement, the control arms are tight, and the tie rod ends seem to be OK. The truck steers well on the road and brakes well. It's an '02 2500. Appreciate any suggestions.
Re:front end "loose"
I've seen or read about the following being possible causes the cluncking problem you describe:
1) Loose shock absorber bolts - common
2) Worn factory shocks
3) Worn stabilizer bar end links
4) Loose intermediate steering shaft couplings
5) Loose intermediate shaft slip joint
Do a search for this issue you'll find more.
Matt
Matt
Strick
Aug 25, 2009 12:38 AM
WhozNxtLS1
Apr 12, 2009 11:24 PM
Leaky Gasket
Aug 14, 2008 07:17 AM
