DIY: Blower Motor Fix
It's an old trick, but, still works.
If your blower motor squeaks or sounds as if it's just all it can do to spin. Remove it and drill a 1/8" hole in the nipple looking part of it. (center of the back side, where the end of the shaft is). Add a couple drops of oil, spin it by hand, add a couple more drops. Then, with it in your hand, connect it back to power and see if that cured it. If so, seal the drilled hole with a dab of rtv silicone and re-install. When/IF it acts up again, no need to remove. Just clear the silicone, re-oil, and re-seal. Use something heavier than wd-40. |
motor fix
Originally Posted by Redlinear
(Post 3157369)
If your blower motor squeaks or sounds as if it's just all it can do to spin. Remove it and drill a 1/8" hole in the nipple looking part of it. (center of the back side, where the end of the shaft is). Add a couple drops of oil, spin it by hand, add a couple more drops. Then, with it in your hand, connect it back to power and see if that cured it. If so, seal the drilled hole with a dab of rtv silicone and re-install. When/IF it acts up again, no need to remove. Just clear the silicone, re-oil, and re-seal. Use something heavier than wd-40. Thank you. |
Originally Posted by hhrumph
(Post 3157588)
Redlinear= Good info. LPS-3 would be a better choice then WD-40.
Thank you. |
