A/C vents not working
A/C works fine, but it only blows out of the lower vents by your feet, no matter what position you have the selector on. Anybody ever had this problem before and a solution to this problem would be appreciated.
First make sure you don't have a vacuum leak by running the engine for a short time, let it sit for five minutes then disconnect any vacuum hose.
It should hiss, a leakless system will hold vacuum for hours if not days.
If its DEF only you most likely have a vac leak. I think the most probable spot for leaks are at the supply line going through the firewall beside the heater hoses. trace this line under the hood and look for breaks/cracks.
Sleigher
May 4, 2017 02:12 PM
hognutz
14
Sep 15, 2009 06:53 PM
bobem12
Jun 17, 2008 12:14 AM
