brakes sticking
anybody else have problem when they first start up truck, and press the brakesthey will stick and skid a bit. it happens not all the time but is annoying and not very safe the brake fluid level in normal and brakes dont squeak.. I experienced this same thing while test driving another truck before I bought mine. any comments?????
Re:brakes sticking
Truck usually does it when its damp out and will grab the firat few applications. If its more so the rear brakes I would check to make sure the rear axles seals are not leaking causing this problem.
Good Luck Jason |
Re:brakes sticking
Yeah.. Mine does it when it rains a lot and I first start. I have gotten into the habit of riding the brakes alittle to dry them off before I get going to fast.. One of these days I will have to look in to this... CAn you tell which one is sticking?? Mine are the front...
Re:brakes sticking
cant tell wwhich ones it is yet . usually happens when pulling out of real tight garage going real slow i will try and figure it out
