Brake pedal issues after emergency braking
So i had to do an emergency braking on hiway truck was unloaded at the time, immediately after the pedal went to floor abs and brake lites on
Brake lite is now out but abs lite is on, truck stops but pedal is to floor, no leaks , no loss of fluid In the fall i had replaced the steering pump and a hydroboost line after the line was leaking at the crimped fitting bad I have seen mention of this being a bad master cylinder or hydro boost, but no resolution Help is apriciated |
