Adding factory fog lights?
I would like to add factory fog lights to my 2001, has anyone done this? I had them on my 96 1500 and liked the way they worked in the fog. Is there a kit, what all does it come with?<br>Is there wiring already there that can be used? Are they switched on with the headlight switch? If so I need to replace the headlight switch?<br>Any part numbers for the kit?<br>Thanks<br>Robert
Re:Adding factory fog lights?
If you use the search function above, there is a thread that gives the parts numbers for adding the factory fog lights. And yes, you must replace the dash switch with one that pulls out for the fogs.
I have done this twice installed kit from dodge on a 2001<br>2500 then traded truck so removed and reinstalled on a 2002<br>3500. Wife bought as a kit from dodge complete with wiring harness light switch ect. the plastic rivets that come with the kit are really cheap , to mount the plastic for the lights(inserts that replace stock gray bumper inserts) i subbed bolts instead and to put back on fascia peice I had some push style black keepers but You can buy those at any store<br>You do have to remove the bumper and the upper fascia,if you sub bolts for rivets remove lower fascia also. Firrst install about 3 hours second time only about a hour(practice makes perfect)
I found them online at:<br>www.wyckoff-mopar-parts.com/19dodramoest.html<br><br>The web page lists kit part # 82205656 , for $152.10<br>I sent them an e-mail asking them if this was a complete kit, they said yes and sent me a price quote number that must be<br>included in the order, the quote price is $135.20<br>
Theres a couple of guys on ebay selling factory kits just to let you know .<br>Do a search : Dodge Ram Fog Lights <br>I'm sure they'll come up <br>
gcliburn
02-05-2013 04:59 PM
fjbiker86
37
12-09-2007 07:29 AM
806 Southern In
20
01-31-2004 09:50 PM
