Big Brake update
Old Aug 8, 2007 | 08:49 PM
  #76
slowflyer2112's Avatar
I think it only works on the four wheel drives. Check the back of your spindle assembly and tell me if the caliper bracket is bolted on or part of the assembly?
If it bolts on you might be able to do this upgrade.
Old Aug 9, 2007 | 12:42 AM
  #77
hipsi's Avatar
Ummm...
I will look again next week I have to have my tires balanced.
Old Sep 18, 2007 | 08:43 AM
  #78
mitchellalso's Avatar
Are the calipers on a '02, 2500 4x4, the same as the ones on a '03 or would I have to change both rotors and calipers?
Old Sep 19, 2007 | 10:13 PM
  #79
Fishin2Deep4U's Avatar
Good info guys. And I am just bout ready for brakes.
Dave
Old Sep 24, 2007 | 02:14 PM
  #80
Update:
I got my 19.5s on the truck and have ordered the brake parts from Beaverton Dodge (Mopar Parts America-the advertise on this site)
The brackets were about 37.00 each + shipping and I also ordered the larger dust shields and may have to redrill them to fit. about 18.00 each + shipping.
I went to Auto Zone and purchased two new rotors for about 120.00 and will be picking up the pads for about 50.00 bucks. I plan on disassembling the calipers and making sure they are in good working order before putting the bigger brakes on.
In looking them up on the web site I found out that the brackets are listed as the same part number for the 2 wheel drive trucks. this means that the big brake upgrade will work on the 2 wheel drive trucks the part numbers are:
#5093268 AA
#5093270 AA
I hope this helps and I'll be giving a report on the braking performance improvement.
Old Sep 24, 2007 | 02:20 PM
  #81
Calipers are the same, just bigger rotors, brackets, and pads.
Old Sep 25, 2007 | 06:40 PM
  #82
Dennis's Avatar
Has anyone verified that the 16" stock wheels will not work? It's brake time on my 2001 4x4 and new wheels and tires are not in the budget.
Old Sep 27, 2007 | 02:47 AM
  #83
Yes its been confirmed. You must use a bigger wheel, at least a 17".
Old Oct 1, 2007 | 11:05 AM
  #84
Dennis's Avatar
Originally Posted by coalburner400
I was going to try my 16" wheels to see if they fit, but after looking at the 17" wheels there was only about 1/2" to 5/8" of space. If they did fit, it would probably be too close for comfort.
Do you think a little bit of grinding on the calipers might let get away with my 16" wheels?
I'd sure like to take advantage of this.
Old Oct 7, 2007 | 09:55 PM
  #85
Finally got my big brakes on the truck. You do notice the difference when stopping. Will be towing a 7000 lb trailer tomorrow and will let you know if it helps.
This will also work on the two wheel drives.
I could not install the knew larger dust shields unless I pulled the hub apart, will have to wait until I need bearings.
Total cost (figuring I needed new brakes) about 100.00.
Old Oct 8, 2007 | 09:40 PM
  #86
heykw's Avatar
Will the big brake caliper mounting bracket mount to a 98 knuckle? I think that you could use a 2001 hub assembly with the slip on rotor and the kit would work.
Old Oct 8, 2007 | 10:15 PM
  #87
heykw's Avatar
Does any one have a pic of a 98 or so knuckles and caliper brackets?
Old Oct 10, 2007 | 05:28 PM
  #88
heykw's Avatar
Some one must?
Old Oct 10, 2007 | 09:36 PM
  #89
If the truck your talking about is an early 98, put the pics up and I'll compare them to mine. I could also send you my old brackets, and if they fit, then the new ones will.
Old Oct 10, 2007 | 11:07 PM
  #90
heykw's Avatar
The truck has a 12valve so I guess it is early 98?
