agrivating speakers
agrivating speakers
has anyone else had trouble with their door speakers jus coming on and off whenever they want. mine will come on for a week and sound fine then one day they wont work for a week. its been getting really aggrivating and was wonderin if anyone has a solution. thanks
Pop your door trim off and take a peak at the connection. The way the door is designed a small amount of water actually comes in the door and drains out the bottom. Early 98.5 and 99 trucks had this problem.
A revised speaker (with a rain cap) was issued, but only when a unit was taken in under warranty.
Obviously you are out of the warranty period so you'll want to find the bad/corroded wires at the connection and either clean them up or bypass the connection altogether and make your own. Just make sure to seal the new connection up very good and you'll be fine.
Replace the speakers, the stock speakers are junk.
Mine did something similar until I replaced them. Even considering that one must have been broken, there was a significant improvement in sound quality. Well worth it. You don't need particularly expensive ones - I recommend Panasonic. Paid $160 CAD for both front and rear.
newguy2005
Dec 30, 2008 09:18 PM
. Finally got sick of the stock junkers and replaced 'em with aftermarkets. No problems after that.
