'99 dashboard is self destructing
Is there a decent aftermarket dash replacement? Mopar wants $500 for the stupid piece of plastic. Everywhere there is a monting screw into the firewall the dash has cracked, some place so bad that the defroster vents are now a seperate piece on their own [verymad] .
ya might find a decent one in a junk yard for cheap.
Try geno's garage...they list a replacement dash for 120 bucks.
You're not alone. Mine cracked from the windshield all the way down to the airbag for some reason. Fine one day and cracked the next. :confused: If you replace it, let me know how it went. The dealer gets like 7hrs to replace it. I could see it being kind of a pain, but 7hrs? Now I remember why I fix stuff myself.
Not only does that sound like a pain, it sounds like a challenge. I guess I'll set the whole day aside for that job. Thanks for the abbreviated install instructions
Last I checked that's a cover, not a replacement. I have the same problem as the OP but like him have not found a reasonably priced replacement yet. Something about just covering up the horror that has become my dash just doesn't sit well with me. I'd even do the replacement myself if I had any idea how to get that **** dash out without breaking 10 other things. |
I picked up one from a junkyard for $125 -- dash top and front (both of mine were cracked/busted when I bought the truck). There are about a hundred screws and six bolts/nuts. Run a search and you should be able to find detailed instructions (try "dash remove"). It took me most of a Saturday to replace the dash top and front -- took it slow to make sure I didn't miss anything, and cleaned out the air ducts while I had access to them.
Ah crap!!!! I thought I left the crackinh dash syndrom behind when I sold the Chevy??? U guys telling me that this one is going to do it too?? Guess I beeter get a dash mat on it before things go south.
Originally Posted by CSAGrey1
I thought I left the crackinh dash syndrom behind....
Aaaccckkk. Now I'm REALLY not looking forward to pulling my dash! I have a plugged tube in the A/C evaporator housing thats leaking water on my floor any time I run A/C. I have been postponing removing the dash until I had a bunch of time free.
Jim |
Jim Try this link for instructions on "tilting" the dash: https://www.dieseltruckresource.com/...t=dash+replace NHDiesel, make sure you actually have a plugged tube before tearing into the dash -- there are also several threads regarding the need to add an extra "drip tube" to keep water from coming back inside (been there). |
don't forget to disconnect both batteries so you don't set off the airbag and need to change shorts...
[duhhh] That has got to suck!!! |
Jim Chris |
Two bolts that hold the steering column. Let it drop to the seat. (If you have a auto - unhook the string to the PRND21 pointer...) From the linked thread, I found this confusing. WTH is a PRND21 pointer? |
| All times are GMT -5. The time now is 03:25 AM. |
