96-2500 leaking like a siv
Old 12-06-2011, 06:54 PM
Liked 0 Times in 0 Posts
Unhappy 96-2500 leaking like a siv
All of a sudden my truck has water pooling on the floor infront of and beneath the front seats. It only happens when it rains, doesnt matter how hard and the truck is just sitting. I cant find any drips or visible trickles of water.
Dont want my floorboards to rust out.
96BigBlue is offline
Old 12-06-2011, 10:02 PM
Brian08Q35004x4's Avatar
Location: This Nazi state of California 2nd home Gilbert AZ under God
Have checked the door and windshield drains? It is a 96 and dirt,rust and even factory labels could be blocking the drains causing backup into the cab
Brian08Q35004x4 is offline
Old 12-07-2011, 01:24 AM
kawi600's Avatar
Check the rear window and the 3rd brake light.
if thats not it, try lifting the carpet and look for rot where the firewall slopes down to the floor.
kawi600 is offline
Old 12-07-2011, 11:27 AM
SIXSLUG's Avatar
Liked 40 Times in 36 Posts
Usually the third brake light gasket is dry and cracked.
If it doesn't smell like anti freeze its probaly not ht heater core, however the A/C condenser drain tube can get blocked and back up into the passenger floor. Its on the fire wall under the hood lower right side.
SIXSLUG is offline
Old 12-10-2011, 12:14 AM
Liked 2 Times in 2 Posts
my drivers side is a swamp too, like standing water on top of the carpet! Where should I look for seals and drains? The headliner is wet just above the drivers seat next to the drivers window, but the seat and door is dry. can it still be the 3rd brakelight seal?
joem is offline
Old 12-10-2011, 01:23 PM
SIXSLUG's Avatar
A wet headliner sounds like a poor seal between the door and cab, or a bad window seal.
The third brake light gasket is the first place to look on the passenger side, then the a/c drain. For the drivers side i'd guess door/window seals. Or a window left open in a downpour.
SIXSLUG is offline
Old 12-10-2011, 08:30 PM
Admin Team Leader
Lary Ellis (Top)'s Avatar
Liked 189 Times in 142 Posts
Yep 3rd brake light seal will get ya every time
Lary Ellis (Top) is offline
Old 12-10-2011, 10:50 PM
I will make a quick video of the leaks and destroyed headlinter sunday, its terrable and has been leaking well before i bought it- rust on the metal seat supports and mold on the seatbelts. no fun in a area that gets 100" of rain a year.
joem is offline
Old 12-11-2011, 12:15 AM
Liked 10 Times in 8 Posts
Ditto on that sneaky 3rd brake light. I pulled mine and used 3M body putty--the stuff that comes in ropes--to reseal it. Hasn't leaked since.
Robert Rausch is offline
Old 12-11-2011, 09:19 PM
joem is offline
Old 12-12-2011, 09:30 AM
Liked 3 Times in 3 Posts
Easy way to pinpoint leaks is to tape over the exhaust vents located on the lower rear door frame.
Turn the fan on high to pressurize the cab.
Spray soapy water on the suspect areas, bubbles will lead you to the leak.
infidel is offline
Old 12-12-2011, 10:33 PM
Diesel_Dawg's Avatar
Liked 79 Times in 48 Posts
My truck leaked water on the passenger side floorboard when parked facing down hill and the cause was a tear in the plastic sheet behind the door panel (AKA Water Dam in the parts manual). Once I replaced the water dam my cab has remained dry.
Diesel_Dawg is offline
Old 01-01-2012, 02:46 PM
First dry day in months, here is the rear brakelight- not much of a seal left.
joem is offline
Racing_Joe66
10-04-2013 11:58 PM
lilsuzuki4x4
09-01-2011 01:50 AM
Racing_Joe66
17
04-26-2010 08:09 PM
t-15 firefighter
12-14-2005 10:54 AM
600 Megawatts
11-01-2005 08:20 PM
Quick Reply: 96-2500 leaking like a siv
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
