'94 2wd Front Suspension Height
Old 10-31-2012, 11:31 AM
jstone44720's Avatar
I am trying to find a good way to tell how much / if my front springs have sagged out in the last 250k miles. It rides very harsh, and I am looking for a good reference to measure. I am running stock size tires. Ground to fender lip or something like that would be much appreciated.
Old 10-31-2012, 04:50 PM
patdaly's Avatar
Don't have 94, but 97 should be the same, this is frame dimensions, might help.
Old 11-01-2012, 08:11 AM
texasprd's Avatar
Interesting - what measurement scale (millimeters, centimeters, inches, etc) is that based on?
Old 11-02-2012, 08:03 PM
traverler48's Avatar
When I broght my truck home in Sept 94 I measured the front where the wheel well starts to turn under in the middle of the rim 34 1/2". rear 37 5/8" with stock tires still the same today 117K. Its on my shop wall.
Old 11-03-2012, 07:29 PM
patdaly's Avatar
Pretty sure it is MM
Old 11-04-2012, 07:33 PM
Thank you. That should do nicely. I am expecting to find them sagged quite a bit. Any idea if the measurements are with or without fuel?
Old 11-05-2012, 11:29 AM
texasprd's Avatar
Pat, I don't think it is millimeters (or even centimeters) - at least, not in all cases. If you run those measurements through a metric/English conversion, you don't get reasonable numbers for some of the dimensions.
For instance, the "100" dimension from the bottom of the transmission crossmember - 100mm is 3.94 inches, and 100cm would be 39.37 inches. Neither is reasonable for a crossmember-height for a stock 2WD. However, the "913" dimension between the mounts on the outside of the front frame horns converts from millimeters to 35.94 inches, which may be reasonable. Maybe a different basis is used for height than width? Or maybe the ground isn't the starting point for the height measurements?
Old 11-05-2012, 12:22 PM
patdaly's Avatar
That was my conclusion as well, perhaps a factory jig? In any instance, I would take the relative difference at 2 or 3 points and compare them with my actual, so if front inspection hole is "Y" above rear spring mount, I would call front measurement rear actual ht. plus "Y".
Old 12-13-2012, 10:20 AM
Thanks for clearing all that up guys. I was wondering how my truck was 5 inches taller than it was supposed to be.
Tejas TJ
03-24-2011 05:18 PM
LongRanger
02-02-2010 10:03 AM
mudwisr2
01-28-2009 09:42 AM
rustram96
02-05-2008 03:44 PM
mestdagh
05-07-2005 07:23 PM
Quick Reply: '94 2wd Front Suspension Height
