-   2nd Gen. Dodge Ram - No Drivetrain (https://www.dieseltruckresource.com/forums/2nd-gen-dodge-ram-no-drivetrain-90/)
-   -   #1 and #2 fuel differences??? (https://www.dieseltruckresource.com/forums/2nd-gen-dodge-ram-no-drivetrain-90/1-2-fuel-differences-222286/)
robert78.5 11-04-2008 11:51 AM
What is the difference between #1 and #2 diesel at pumps besides price???
dodge2001 11-04-2008 04:48 PM
someone please correct me if i'm wrong...but #1 fuel is for the colder climates...it has some anti-gell stuff in it...some stations sell the #2 in the spring, summer and into the fall. then switch over to the #1 in the winter and into the start of spring.
megacabdad 11-04-2008 05:08 PM
Reading this might clear some things up for 'ya a little...
http://www.rxp.com/DieselFuel.htm
b4black 11-05-2008 10:03 AM
Diesel #1 is slightly 'lighter' (less dense) than diesel #2. It's primary benefit is that is has a cloud point of about -40°F, so it is better for cold climates. Cost more and gives slightly less MPG. Use just enough to prevent gelling.
It's commonly called Kerosene.
infidel 11-05-2008 10:34 AM
No real reason to use #1 unless you're in an arctic climate. #1 has less btus which result in lower mpgs and power.
Straight #2 with antigel additive will offer close to the same amount of protection. Most stations in the lower 48 don't even offer a a 1/2 blend since additive is so much cheaper and easier.
Lots of info about fuel here http://dodgeram.org/tech/dsl/FAQ/diesel_fuel.htm
