Mark this thread as Unsold
Truck For Sale 1995 Dodge ext cab diesel for sale $5,000
This truck runs great and needs nothing to be a consistent daily driver. It is a 1995 dodge 2500 diesel 2 wheel drive. No tears in the cloth seats. It has the small back seat but doors do not open. The dash is cracked and the hood and cab top paint are going. I got a econo paint quote at $600 for the whole truck. It is all stock except a 4" exhaust and extra large air filter. No wrecks. The only reason I am selling this is because I purchased a four door truck. Partial trades for skid steer or backhoe. Located in Central Texas. Maintenance records:
160,000 dowel pin tab
167,500 oil, filter, lube, fuel filter
175,000 oil, filter, lube
182,500 oil, filter, lube
190,000 oil, filter, lube
190,000 thermostat
197,500 oil, filter, lube
195,000 brake pads
205,000 oil, filter, lube
205,000 trans fluid, filter, band adjust
210,000 ball joints, tie rod ends, sway bar end links, control arm bushings, pitman arm, idler arm, front shocks
212,500 oil, filter, lube
212,500 belt tensioner
215,000 ac compressor, dryer, orifice tub
220,000 oil, filter, lube
227,500 oil, filter, lube
232,000 brake shoes, drum turn, axle seals, axle fluid
233,000 1 gallon trans fluid, coolant flush
234,000 washer fluid pump
235,000 oil, filter, lube, air filter, fuel filter
190,000 thermostat
195,000 brake pads
Flashdancr
Oct 17, 2005 02:02 PM
