Wheel bearing?
Wheel bearing?
Noise coming from the front. Noticeable when I start driving and slowing down. Sounds like I have wide mud tires. Not sure if it’s the bearing or not. Any suggestions?
Also, what is the recommended ft/lbs for 8 lug. Currently at 135 ft/lbs.
4x4? Could be u joint at wheel bearing or even front driveshaft....4x2, maybe unit bearing. Oversize tires with Jr. 4x4 offset? I'd bet unit bearing. 135 ft/lbs is what I twist on stock aluminum wheels......
Received 1,637 Likes
It would be helpful if you said what truck you have. Year and model
There are different torque values depending if you have a 3/4 ton vs 1 ton axles. Different lug nuts, different rims, different studs, etc
Ford's and GM trucks came with 8 lug axles, and I bet they have different values as well
nothingbutdarts (07-01-2019)
Tannon Jeffries (11-29-2019)
silverbullet02
10-05-2009 12:16 PM
Wilbur01
08-03-2009 11:16 PM
wadecool
01-12-2007 11:39 AM
Joseph H. Smith
16
01-06-2007 08:13 PM
jaconst
04-02-2006 03:02 PM
