What's with these banjo fittings??
A few weeks ago I had changed out my lift pump, and every since then I cannot get the banjo fitting on the back side of the fuel bowl to stop leaking. I am afraid to crank on it anymore for fear I'll break something. Do you have to replace these washers everytime you remove a banjo fitting? Someone please help me out, this is very frusterating and painting my garage floor in diesel every night is starting to make the wife cranky....ha ha.
Just my $.02
Good Luck.
Torque for those banjo fittings is 18 lbs. Some washers are all copper and some have a rubber center. If the leak then do as advised or replace the washers. You made sure you have one on "each side" of the banjo, right.....?
Lektrikman
02-02-2008 10:00 PM
kawi600
10-21-2006 10:09 PM
