Whats happened to 1st gear
Old Sep 22, 2010 | 11:31 PM
Crazyhorse's Avatar
My tranny starts out in second gear, I have to manually shift it to first in order for it to go into first. Any suggestions would be great. Im planning to rebuild the trans soon so any suggestions as to what I may want to put in it would be greatly appreciated.
Old Sep 23, 2010 | 05:15 AM
jughead's Avatar
first gear
1-2 shift valve stuck or gov circuit problem.
Old Sep 23, 2010 | 10:54 PM
Crazyhorse's Avatar
where is the 1-2 shift valve I have already replaces the governor solenoid and sensor
Old Sep 24, 2010 | 03:03 AM
jughead's Avatar
one needs a manual to look at pics of valvebody to see where it is. my bad on the electronics. i dont know if there is a solenoid for the 1-2 valve or not. i do know that if the valve is stuck in the open position it will take off in 2nd gear and will only work in manual low.
Old Sep 24, 2010 | 06:40 AM
j-fox's Avatar
Check it for codes set.
It is in limp home mode.
Possible causes, gov. pressure sensor and or transducer, and speed sensor.
Common
Apr 9, 2008 10:25 PM
flashgordon
Mar 26, 2006 01:27 AM
The Domie
Jan 6, 2005 02:23 AM
spassey
Jan 25, 2003 12:08 PM
Huey
Oct 11, 2002 07:41 PM
