What size socket for MAP sensor
Old Aug 2, 2006 | 08:05 PM
reddawg's Avatar
does 98.5 have the Iat sensor and what does it do and where is it located
Old Aug 2, 2006 | 08:34 PM
crobtex's Avatar
Yes, if it's a 24v. You can find it here .
Old Aug 2, 2006 | 09:09 PM
dsl kicks gas's Avatar
ok ive heard of people unplugin the map senser, and leavin it unpluged. what would that do?
Old Aug 2, 2006 | 10:06 PM
BigBlue's Avatar
Only unplug the map sensor if you have an Edge Comp. Otherwise leave it in.
Old Aug 3, 2006 | 01:49 AM
jrs_dodge_diesel's Avatar
http://dodgeram.org/tech/dsl/mt_2_fe...l_sys_comp.htm
The MAP and IAT are both on the drivers side of the engine towards the back along the intake manifold.
#7 is the IAT sensor, it measures the temp of the air before it enters the cylinder.
#8 is the MAP sensor, also referred to as a boost sensor. It measures the pressure oif the intake air.
The ECM uses them to fine tune the amount of fuel injected into the engine.
BorntoHunt
Jun 10, 2008 09:22 PM
scout98
Dec 8, 2007 04:45 PM
hamilton71801
Jul 31, 2007 06:44 PM
mamm7215
13
Aug 7, 2005 11:29 PM
rich
Feb 23, 2004 07:36 PM
