what seal is this?
Old Dec 17, 2006 | 08:22 PM
dieselfan's Avatar
what seal is this?
im trying to find out, where the transmission meets the drive shaft. what seal is in between?
i was under my truck today and i noticed a little oil leaking from where the tranny meets the drive shaft.
it could be normal but i dont know, it was only a little, not even a drop on the ground.
is this the carrier bearing leaking?
thanks dieselfan
Old Dec 17, 2006 | 08:32 PM
dieselrob's Avatar
If you mean the tail housing on the end of the tranny Then that shuold be you output shaft seal. Mine seeps ever since i put amsoil in it.
Old Dec 17, 2006 | 08:35 PM
dieselfan's Avatar
yes the tail end. is this normal, it is only a seep, i looked on my buddy 2002 and the same amount was there.
thanks dieselfan
Old Dec 17, 2006 | 08:42 PM
iker42's Avatar
Yep, ours has it as well and i believe it is the output shaft seal
Old Dec 17, 2006 | 08:43 PM
ratat98's Avatar
Mine does this too..I just keep tabs on the fluid level and don't worry about it that much
Old Dec 17, 2006 | 09:10 PM
dieselfan's Avatar
thanks everyone, this thread makes me feel a little better.
Old Dec 17, 2006 | 11:01 PM
cumminspower79's Avatar
Dont know if its the same seal as the 4x4, but mine was seeping, then over the course of months it turned into a drip. My rear end and fuel tank had spots all over them. Went to the dealer and bought a new one and it took ten minutes to change.
Old Dec 18, 2006 | 06:10 AM
dieselfan's Avatar
do you remember what it was called? part #? price?
thanks diseslfan
RTillery
Feb 7, 2009 08:46 AM
pwrtripls1
Jan 7, 2008 08:55 PM
dieseljerk
Jul 8, 2004 07:23 AM
SSV1761982
Jun 24, 2004 11:15 AM
