What do these codes mean?
My truck is putting out these codes with the key cycle trick:
P0500
P1693 (came up two times)
P1687
P0216 (I know this one
Its an '02 ctd, auto: I have an Edge EZ that was plugged in when I scanned it will that make a difference on any of these codes.
Thanks
P0500
P1687
)Its an '02 ctd, auto: I have an Edge EZ that was plugged in when I scanned it will that make a difference on any of these codes.
Thanks
1st is top of the page click on tech facts , about 3 pages deep , code def.
But in this case only 1 of your's were there , speed sensor , it would help if you gave some syptoms that it has also .
And nows a good time to ask why there are so many missing codes in the list ?
I would guess that the computor may affect code info , contact the supplier about there programing if someone does not answer that one .
P0500 - No Vehicle Speed Sensor signal (might be a bad sensor, or could be tripped by wheelspin if you've been stuck recently)
P1693 - DTC in Companion module (just means that a code was set in either the PCM or ECM, since it looks like you have codes in both computers, you're getting multiple 1693 codes)
P1687 - No MIC (Mechanical Instrument Cluster) BUS Message
P0216 - Injection Pump Timing failure - make sure to check out your lift pump and fuel filter as these could cause the code.
Having the EZ plugged in shouldn't cause a false reading on any of these codes.
sorry new to DTR didnt know that link was there.
1-sometimes I get a dead pedal
2-sometimes the trans is OD at 15 mph
3-sometimes there will not be hardly any power(still responds to the pedal but very very slow)
4-and other times it will run like a raped date.
i have a FASS as my lift pump and im pushin 22-23lbs psi idle and 19-20psi @WOT.
what does that P1687 code mean? any thing to be worried about?
to many codes in there for my likeing but thank you for the help.
If you set the 500 code when you were stuck, you probably would have gotten a Brake and ABS light on your dash. Usually it gets set when your stuck and you've either got the rears wheels spinning like crazy without the front moving, or in 4x4 with one front wheel stopped and one spinning. The lights go away after a couple of cycles, the codes stay a little longer.
Never seen the 1687 before, but I'm assuming that it lost communication with the instrument cluster at some point? Ever had your instrument panel go dead or go crazy with a bunch of lights (besides just getting the Brake and ABS from the 500)?
Just got an idea from the last couple of posts , about getting stuck , ther may not be a problum besides the computer program saying the things do'nt add up . so its tweaked.
Go to one of the parts stores that do the reading and have them clear the codes , then drive some and see if that clears the symtems , before doing further diagnostics .
Originally Posted by Phatboy
In OD at 15 mph? I haven't drove a dodge auto, but this definately sounds wrong. The 0216 causes #1.
yea my cousins '01 does the same thing if we put them into 2nd gear when it does this they go on like normal then put it back into OD and everything is ok.
ill try resetting them it has happened more then once to me.
no that has never happened to me.
cumminsman02
Apr 29, 2005 09:02 PM
