What is an acceptable fuel pressure
Old Apr 21, 2006 | 12:27 AM
abbeyinc's Avatar
My fuel pressure gauge shows 11-12 psi at idle and 6-7 at full throttle.
Stock LP.
What does everyone think?
Old Apr 21, 2006 | 12:58 AM
caffecapri's Avatar
With my FASS system, I get 16-17 lbs of fuel pressure at idle. Not sure what it was before as I did gauges at the same time.
Old Apr 21, 2006 | 06:00 AM
JD730's Avatar
Stock LP.
Sounds like a stock system, mine runs 12-14 psi at idle, with a smarty and injectors I can drag mine down to 4 psi at WOT.
Old Apr 21, 2006 | 06:32 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Sounds like it's a little on the low side.
Borderline for now, but keep a careful eye on it, and start shopping for a replacement.
I see 15-16 @ idle & 9-10 at WOT.
Stock lift pump w/ Scotty's Smart Fuel System.
Old Apr 21, 2006 | 08:35 AM
farmer13's Avatar
Mine is about the same, can drop it down to 5psi at WOT, stock lift pump. ordered a Scotty fuel kit yesterday.
Old Apr 21, 2006 | 09:52 AM
HOHN's Avatar
Scotty's fuel kit will help a lot.
If you have 8psi @ wot, I'd say you're fine. A little below that is OK, just don't like it drop to 1 or 2 for any considerable amount of time.
jh
Old Apr 22, 2006 | 02:00 PM
johnh's Avatar
fp
Stock LP.
looks good to me
Old Apr 22, 2006 | 02:21 PM
Tiny's Avatar
When it gets to 4-5 lbs. it is time for action. OK till then.
Old Apr 22, 2006 | 03:26 PM
Yukon Dodge's Avatar
I know where you live! And I wouldn't hesitate to replace it asap!
Old Apr 22, 2006 | 03:45 PM
smokindog's Avatar
Yep,
Most FP gauges that you will find rated for diesel start showing the little red warning line right around 5psi. With that said 5psi was the limit a couple years ago, but I hear more and more folks saying that anything under 8psi will require attention rather soon.
jtrimmell
Oct 8, 2007 12:24 AM
Cowboy_Customs
Jun 25, 2007 03:20 PM
Fishbait
May 18, 2004 09:39 AM
joefarmer
Oct 19, 2003 01:58 PM
ABQMac
Oct 18, 2002 05:20 PM
