-   24 Valve Engine and Drivetrain (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/)
-   -   Vp44 Ecu? (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/vp44-ecu-226373/)
cody_d Dec 13, 2008 05:18 PM
Vp44 Ecu?
Is there any way to change the electronic control unit on the VP44? If no then where is somewhere that i can get a cheap pump in utah? just got married a few months ago and with christmas upon us money is squeeky tight. Thanks for the info and help.
johnh Dec 13, 2008 10:36 PM
no way..... where in ut are you
http://stores.myregisteredsite.com/u...VP44+Fuel+Pump
dozer12216 Dec 13, 2008 10:37 PM
I'm sure there is a ability to change. The problem is each brain box is tuned for pump delivery rates it is mounted on. JMHO
cody_d Dec 13, 2008 11:51 PM
i'm in farminton. I know there is Industrial injection in salt lake and bakers in ogden. but i don't know which is better. Is there any way to nurse the thing untill i can afford a new one? or does it just go when i feels like it? I had a hypertech max energy on it and it started to pulse after i put the programer on it.
should i also replace the lift pump when i do the VP?
dozer12216 Dec 14, 2008 11:09 AM
There are several mail order and ebay places that offer pumps in very low 1000 dollar range, perhaps less. To my knowledge they offer same pumps irregardless of statements promoting justification for higher price. Same warranty. Yes, replace LP unless you are absolutelly positive it is sufficent. Like it was replaced 2 months ago and pressure test shows 10 PSI. I sort of assume you have seen 216 code from statement. You are on borrowed time for a failure if correct.
cody_d Dec 14, 2008 01:14 PM
the only codes i have seen are P1688 and 1689. which after some research i have found they are both IP failure to comunicate codes.
johnh Dec 14, 2008 04:20 PM
bakers are ok , check their prices .....they will get the vp44 from ind inj [coffee] i have a friend in west jordan that might have a used one for a '01 HO
johnh Dec 14, 2008 04:26 PM
Industrial Injection is an authorized Bosch rebuilder and installer, they will have one on hand .... bakers is just a shop that installs
Gerald Girljr Jun 2, 2020 09:19 PM
Just
give you a heads up on those two codes your getting I got those two codes after taking apart half my truck it came down to my vp44 no common between the edu and the McD's or what ever the he'll it said I watched a video of them pulling the cover off the controls unit on the VP 44 that is what my problem was bad solder on the contact and little where's 1 was burnt in half and the plat that they were all hooked to was not connected any more re soldered it and wala.lot cheaper than 2000 bucks plus 1000 core charge for a manufacturer 1 cost 10 bucks mine has edge attitude w juice not unlocked just 1 through 5 not sure if that could of over treated it but ya that's what it was on mine
