VP 44 test to see if it's dead
Old May 11, 2008 | 09:15 PM
psl53's Avatar
Looks like my VP 44 is toast. Good news is that I have 156,000 miles. Before I buy a $1000.00 plus pump is there a test I can do to make sure it's the high pressure pump. It just began to have hard starting and it will only start if it's cold, when it heats up it won't start. It hasn't thrown any codes.
Thanks
Peter
Old May 12, 2008 | 07:22 AM
UBEAST's Avatar
I have been looking at new lift pumps, fass and airdog.....and when reading their manuals I saw something interisting that may apply to your case.....look at page 4 hard start heading
http://www.fassride.com/billcook/FAS...l%20Manual.pdf
Old May 12, 2008 | 11:35 AM
mini14's Avatar
crack 3 hp lines, then crank the engine. if no fuel flows the pump is bad, there is no way to tell which line the rotor stops on hence the need to crack 3 lines. hard to start when hot is a very good indicator of a bad ip.
Old May 12, 2008 | 02:32 PM
psl53's Avatar
Thanks all,
Tried to take it to get checked and it wouldn't start it threw a P0216 code Guess I'm going to order this $1,000 pump..... hope I get a sticker with that
Thanks
Peter
Polaraco
Jun 1, 2011 12:16 AM
dieselripper
Jan 15, 2011 05:53 PM
snowmanx
Jun 6, 2010 01:53 PM
tmleadr03
Dec 24, 2007 10:01 PM
