Verdict on Alliant Replacement Lift Pump for 24V?
I try to do what I can to help, I am like you I don't want to spend money on something I don't need or have to keep replacing. No matter what direction you go, you can still get a bad pump...it happens with any product but FASS builds their pumps in house and they test them multiple times before they ever go into a box to sell
Down time sucks and the whole idea behind DTR is sharing the knowledge so we can help each other from avoiding as much down time as possible
Is there anything in the electrical that can give less pressure? I installed a new carter lift pump as my pressure was dropping to 3 lbs on highway, now when i bump key to get pump to work it sounds faint and 3-4 lbs pressure. As did the old one.
I'd also check to make sure that if you added any aftermarket fuel lines like the big line kit, there are no pinched or folded lines.
I installed my Fass pump last night. First of all, it's no 1 hr job as stated in the ad material...at least not for those of us who've not done it before. It's a tight spot, and all the fuel line connections take some time.
Additionally, I had to disconnect most of the work I'd completed as during test the engine would only run a short time and then die, and my 5 psi warning light was on constant. I figured out that by following the instructions provided by Fass the 8" length for the fuel line from pump to filter canister inlet as specified was too long causing a sharp bend in it. This creased the line enough to inhibit flow. I shortened it, and carefully positioned each banjo bolt to insure a soft bend in the line and no kinks.
Works great now! My 5 psi idiot light never flickers even under heavy acceleration as it did with my Carter, and the torque curve seems much stronger into a higher RPM range.
Glad I was convinced to go with this pump, and again I thank Lary for his direction!
greenworks
10-19-2005 10:17 PM
NJMurvin
21
04-22-2005 08:38 PM
