Valvey sound help me solve
Started the truck up and puff of white and a little bit of hesitation/ hiccups. Started going down the road and no power, so I limp it back home.
Throw the scan tool on it and nothing showing , go back down the road with scanner on and it acts all normal ,shows nothing, and drives fine. Thing almost sounds like a old 7.3 power stroke valvetrain.
Im gonna pull the valve cover and just take a look. Where should I start on diagnosing this issue?
Check valve clearance, and take notes on what you find before adjusting to proper specs.
The Cummins can be low on power without codes for a lot of reasons like air filter, fuel filter, lift pump etc.
Will do. It has fairly large cold air intake that’s clean & airdog fuel system that Has under 500 miles since filter/ water separater change also shoving 14psi through 1/2 inch lines to a untapped vp with under 10k miles on it . ( I know they can crap the bed with little miles though but U would think A pump code would be in there if so .
I’ll check this also and report back . We’ve making hay and I haven’t had a chance yet.
tyssniffen
02-17-2006 10:26 AM
diesel honey
08-09-2004 11:43 AM
