Truck has gremlins
Truck went full throttle on it's own wile driving. After shutting her down I lost all throttle response and the rpm's would jump all across the board from idle to redline all on it's own.
Replaced ECM. That was apparently NOT the issue. |
APPS could be out. Try the reset first, but with a new ecm, it should have done it. I put in an ecm ecm and had some weird stuff the first restart.
Try to reset the apps and see what happens. |
Apps reset did not work. After replacing the computer the idle stays smooth and no longer jumps around but I still donor have any throttle response.
Bump
Any codes?
Plenty.
Ecu 0236 0121 0123 0237 0522 1698 0230 0382 |
You seem to be having comm problems and sensor values not to spec:
0236= Boost sensor not functional 0121= TPS does not agree with MAP 0123= TPS value high 0237= Boost sensor low 0522= Oil pressure low 1698= No CCD from ECM 0230= Fuel pump voltage out of range 0382= Intake air heater relay #2 I would see if your Edge drag comp is fooling with this stuff... The oil pressure one is troubling to me, but could be the edge causing that. |
Unhooked the comp and still nothing. :(
All grounds intact and clean, battery cables and ends good?
The random full throttle came back. Checked all grounds. All look clean and tight. Batteries and terminals are new and clean. Unplugged tps/apps and it still revs up on it's own. All codes are gone except a 1488 that I think said aux 5v input low. And another 0328 intake air temp.
Scan tool shows apps going from 0%-100% in 1sec bursts with no one touching the truck. |
That would be coming from the ECM I would think....
I would rethread this with a more catchy title to what is going on to get more bites from guys who can help you with this. Maybe "Intermittent throttle and codes" or something like that. |
I had an edge under the good chip that caused all sorts of weird engine stuff! Like redlining randomly, no throttle and operatic idling!
Still waiting on another ECM. :( should have it Monday
Good luck, man!
I hope that fixes it. |
ON THE ROAD AGAIN!!!!!!!
After two bad ECM's and 3weeks down time she's alive and well. |
