Transmission Dying?
Transmission Dying?
When I left a store this eve my trans decieded to act up. When I shift into drive it feels like it's taking off in 2nd or 3rd. It will go into 1st manually but will not any other way.. Ideals???
Mine did the same thing back in July. Took it to the dealer they told me it was toast. I didnt trust them so I took it somewhere else and they told me the same thing. I ended up having it rebuilt. I dont really know anything about transmissions so they both could have been pulling my leg.
Do the key cycles and get any codes in your odometer readout. Most common prob is gov psi transducer and solenoid. Dealer parts counter should be very familiar with the part numbers and I would be nearly all of them have it in stock. If you can change a trans filter, you can install these parts.
Originally Posted by phox_mulder
Could be something as "simple" as the governor pressure, or the sensor.
That is the usual cause for "limp mode", not starting out in 1st.
phox
phox
Originally Posted by sodbuster03
No codes..other ideals?
I'd try getting it scanned at Autozone or other parts store.
phox
I would recomend taking it to a reputable tranny shop that works on these diesel trucks. They can put it on the scope and find out what is really wrong. Could just be a speed sensor or something simple like that. It is worth the professional diagnostics IMO.
