-   24 Valve Engine and Drivetrain (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/)
-   -   Transfer Case Seal Leaking (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/transfer-case-seal-leaking-49433/)
Rauschbo Aug 18, 2004 05:06 AM
...my NEWEST leak is the seal at the rear of the transfer case extension housing (where the drive shaft comes out); As I'll be needing to pull the drive line to swap out the seal, do you guys recommend that I change out the U-joints and carrier bearing at the same time (I've 100K on the thing)? Are there any gotcha's that I'll be encountering?
Thx / Rauschbo
