Transfer case pic
Old Oct 23, 2010 | 12:02 AM
wyattearp29's Avatar
Transfer case pic
this is what my transfer case looked like when I broke it.
Old Oct 23, 2010 | 03:57 PM
johnh's Avatar
how did you do that??????
Old Oct 26, 2010 | 07:59 PM
My front drivline bolts came out . one stayed in and rotated around and hit the cross beam. This broke the case.
Old Oct 26, 2010 | 08:14 PM
Hodge's Avatar
Mine did the same thing last December, on the eve of a 27" snow. Needless to say, I check those bolts every now and then, to make sure they are still tight.
Old Oct 26, 2010 | 11:36 PM
so is this a common problem
Old Nov 10, 2010 | 05:44 PM
koolkris's Avatar
broken transfer case
last sunday i put my 99 dodge in 4wd and it made a clunk clunk noise! i found out that 3 of the drive line bolts were gone and the drive line swung over on the last bolt knocking a fist size hole in my front housing of my transfer case !!! i thought i must be the only one that ever happened to!!!
Old Nov 10, 2010 | 07:34 PM
Hodge's Avatar
It may seem common, but this (post) is the most that I have heard of the occurance. At least on mine, it was a simple matter that when the transmission was removed and rebuild, I don't think that they used locktite when they reinstalled the bolts. I don't think it is a design flaw- bolts back out. They do need locktite or something else to keep them in, though. At this point, I just periodically check mine, when I am under it changing the oil.
Old Nov 10, 2010 | 07:39 PM
Nick02Ram's Avatar
Thanks guys, timely post. I just had a clutch put in...might have to crawl under there and check them bolts!
wyododge
Aug 18, 2011 07:48 AM
HorseHauler
23
Apr 16, 2010 12:40 PM
DMS1707
23
Nov 5, 2008 12:53 PM
8mpg
May 22, 2006 01:35 PM
