TPS - New - Still No OD
I've just installed the new TPS and gone for a test drive.
This issue with the tranny shifting aimlessly between OD and 4th gear is gone...now it just won't go into OD at all!!! Any suggestions??? I'm trying a 1/2 hour (minimum) reset by disconnecting the batteries to see if that will work. Any other ideas?? |
did u adjust the voltage correctly ? did u take reading before and after install ?
Still NG
The voltage at the stare was .447...and it drove with no OD and still had sporadic shifting with the new TPS...
I adjusted the voltage up...the highest I could get was .778 but this threw a code and I had no throttle...the code was 0122 & 0121. So I put the voltage back to .44 as it was and got throttle response back but now still have shifting back and forth at about 45 - 50 and it won't go into OD...now at 65 mph I'm at 2200 RPM whereby before all this started I could do 68-70 and be at 2000 RPM. |
