Flex Plate selection
Old 02-04-2018, 03:55 PM
mopar440cu's Avatar
Question Flex Plate selection
Anyone have a thought on a good flex plate for a 2001 Dodge 5.9 Cummns with a 47RE? I don't see the need for a billet one I just need a better thicker one than stock. It is just my daily driver that pulls a little 16' trailer. Any thought would help me out a lot!!
Thanks,
Steve
Old 02-04-2018, 05:33 PM
johnh's Avatar
Thanks,
Steve
https://www.xtremediesel.com/bd-powe...-plate-1041210
mopar440cu (02-16-2018)
Old 02-05-2018, 03:42 PM
mopar440cu's Avatar
Thanks John! Its a little pricey like the other billet ones though.
Old 02-05-2018, 04:14 PM
mopar440cu's Avatar
Arrow
I seen this one on the MTS website F2-5.9 for $195 What do yall think of it??
3 Times Thicker than OEM
SFI Rated Flexplate
Designed to handle extreme duty applications
Designed to take the punishment of high horepower engines
4mm thick centerplate
Ring gears are precision robotic welded with cold welding process
Old 02-07-2018, 12:48 AM
oldblues's Avatar
hi
that looks like the one i used inmy 98 12 v .
check it for fit to see that the 4 center tabs locate it on the crank properly and lay it on the converter to see that it lays flat where the 6 converter bolts attach.
iinstalled a aftermarket billit converter and had to jb weld 6 an .060 washers on to converter to make it sit on the bolt pads.
used blue locktite , ben in app 7500 miles and fine .
got mine off e bay less than 100.00! make sure it has the sfi sticker like in the pic !
Old 02-07-2018, 07:38 AM
Received 1,637 Likes on 1,112 Posts
Amazon prw 1835910
Been perfect. $149.00
rangerst
15
02-20-2004 09:50 PM
apache
12-11-2003 01:00 PM
whazzup
08-24-2003 08:21 AM
CR7135
07-14-2003 10:19 PM
Quick Reply: Flex Plate selection
