-   24 Valve Engine and Drivetrain (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/)
-   -   Testing speed sensor wires (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/testing-speed-sensor-wires-211178/)
ramlovingvet Jul 15, 2008 02:37 PM
Is there a way to test the wires to the speed sensor?
Thanks
ramlovingvet Jul 16, 2008 10:43 AM
anyone???
Thanks
dozer12216 Jul 16, 2008 09:37 PM
Use ohmeter. Should have 600 -900 ohms. I allow drive shaft to spin and it will generate a AC votage signal.
Oh! you said wires!!! Engine running, dc voltmeter across wires. Read about 5 volt. With drive shaft turning(very slow) the non black wire should change from 5 v to zero and back.
ramlovingvet Jul 16, 2008 09:45 PM
thanks dozer!!
ramlovingvet Jul 17, 2008 05:14 PM
Not getting any voltage with engine running any ideas???
Thanx
dozer12216 Jul 18, 2008 05:16 PM
Not making connection in terminals. Wires damaged at terminals. Wires damaged elsewhere. Should have code for open circuit or shorted circuit.
ramlovingvet Jul 18, 2008 06:06 PM
Its odd no codes I will hand over hand the wires next.
Thanks Dozer
