Testing speed sensor wires
Old Jul 15, 2008 | 02:37 PM
ramlovingvet's Avatar
DTR'S Chaplain
Is there a way to test the wires to the speed sensor?
Thanks
Old Jul 16, 2008 | 10:43 AM
DTR'S Chaplain
anyone???
Thanks
Old Jul 16, 2008 | 09:37 PM
dozer12216's Avatar
Use ohmeter. Should have 600 -900 ohms. I allow drive shaft to spin and it will generate a AC votage signal.
Oh! you said wires!!! Engine running, dc voltmeter across wires. Read about 5 volt. With drive shaft turning(very slow) the non black wire should change from 5 v to zero and back.
Old Jul 16, 2008 | 09:45 PM
DTR'S Chaplain
thanks dozer!!
Old Jul 17, 2008 | 05:14 PM
DTR'S Chaplain
Not getting any voltage with engine running any ideas???
Thanx
Old Jul 18, 2008 | 05:16 PM
dozer12216's Avatar
Not making connection in terminals. Wires damaged at terminals. Wires damaged elsewhere. Should have code for open circuit or shorted circuit.
Old Jul 18, 2008 | 06:06 PM
DTR'S Chaplain
Its odd no codes I will hand over hand the wires next.
Thanks Dozer
j_k_auto
Oct 21, 2009 03:57 PM
feveree40
Oct 3, 2007 03:59 PM
