Stuck in 2nd gear??
Old Aug 9, 2017 | 06:35 PM
brophyn70's Avatar
Stuck in 2nd gear??
So I will start off by saying that it's a 1999 2500, it is wicked doggy on take off with alot of black smoke witch is unusual for this truck until the turbo spools up, so basically at 55 mph with 3.54 gears it's turning ~2100 rpms and refused to up shift, manually shifting doesn't work either
Old Aug 10, 2017 | 02:27 AM
AlpineRAM's Avatar
Sounds like limp mode of the transmission.
Do check the fault codes and let's go from there,
Old Aug 10, 2017 | 06:24 AM
brophyn70's Avatar
Well that's where I run into issues, there's no light and the obd2 connection has no power when I pulled a code out with the key it was p0749 I believe
Old Aug 10, 2017 | 06:27 AM
brophyn70's Avatar
P0753 is what it is it is still in the system
Old Aug 10, 2017 | 04:00 PM
patdaly's Avatar
That's the shift solenoid code.................. Could still be a couple of things, but I would start by checking out the solenoid.
Some reading to get you started.
https://www.dieseltruckresource.com/...v-auto-222006/
Code P0753 repaired (long) - Dodge Cummins Diesel Forum
Old Aug 10, 2017 | 06:47 PM
brophyn70's Avatar
Hey all well as it turns out, when I had my fuel issue I switched a bad relay to the transmission relay spot, and hadn't driven it since I got it to fire so I threw a new relay in its place and shifts through the gears like a million bucks now
Old Aug 11, 2017 | 08:12 AM
patdaly's Avatar
Great!
Old Aug 12, 2017 | 09:31 AM
AlpineRAM's Avatar
Who would have thought... no power to the transmission results in weird behaviour.
Glad that you found it, and that it was a cheap fix.
birdboy
Dec 12, 2018 09:02 PM
Luckycharm1
Feb 24, 2008 01:01 PM
Baja
Jan 29, 2008 08:17 PM
ClintKeith
Aug 11, 2004 05:44 PM
