-   24 Valve Engine and Drivetrain (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/)
-   -   starter removal (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/starter-removal-116261/)
kinser5mfan Sep 13, 2006 11:46 AM
starter removal
this cannot be done by a man with large forearms!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
i have fought it for 3hours trying everytrick from this forum and another one called two diesel mechanics and it is impossible for a large man to do this!! [verymad]
kinser5mfan Sep 13, 2006 12:14 PM
i did forget to say thanks to those who posted the tips in the first place ( my bad)
GSP Sep 13, 2006 05:44 PM
Are you pop eye the sailer man? Get a super model with skinny arms to do it. Kick back and have a beer and enjoy the view
bentwings Sep 13, 2006 08:40 PM
Wait until it is about 35 degrees out, rain and sleet, all by your self, middle of the nowhere , with only a small mag lite, with cold water creek running under the truck. Guaranteed you will get it off no matter how big you are.
The hot shower afterwards is something you will never forget. [laugh] [laugh]
Tate Sep 13, 2006 10:17 PM
I don't have large forearms, but that shouldn't matter. The hard one to get is the top bolt. Get a 6" extension on a 3/8" ratchet, with the 10mm socket. This should be just a hair longer than the starter, so you'll be able to swing the ratchet. Then work from underneat, snake the ratchet in there. Might take a try or two to get it in, but it will fit. I had the luck of removing it this way. Luckily, my arms are small enough to squeeze in through the top to put that bolt back in.[laugh]
GSP Sep 14, 2006 01:10 PM
Like Tate said , Just use a 3/8 rachet and 6",8" extention and a 10mm socket. I have snap on extensions with the tappered male end so the socket can wobble. Dont thing you need that or a wobbly socket just a straight set up.
Its realy pretty easy to pull the starter.
I think it took me 15 minutes to replace mine
bamadzl Sep 14, 2006 01:21 PM
I wouldn't call my forearms small, and I had no problems. You must have HUGE forearms.
Brad
coalburner400 Sep 15, 2006 06:55 AM
I had read somewhere that someone uses a bottle jack to apply the tq on a modified wrench (to get that top bolt).
Good luck with this. I have not replaced my starter, but I've been there with other impossible tasks. Someone got it in there, there has to be a way to get it out.
stowaway Aug 11, 2025 09:53 AM
starter removal
+i have a 2001 ram 2500. removed the three bolts and starter won't budge. tapped with hammer . no luck. anyone run into this
oliver foster Aug 11, 2025 02:49 PM
You can try jacking off the floor with a block of wood on the jack or the like if you KNOW you have all the bolts removed.
stowaway Aug 12, 2025 08:51 AM
thanks for the info. 2x4 and a big hammer got the job done
