Speed sensor
Old Sep 13, 2006 | 07:36 PM
dieselrob's Avatar
Speed sensor
Any one have there speed sensor in the rear break alot? I loose mine 4 or 5 times a year. And im sick of goin to the salvage yard for them and buying them. Does anyone who races or pulls alot(sledpullin) loose them often. They always seem to break the night im out street racin wit my friens and do boost launches. Any help there. Is there a way to get the sensor in the trans or something other than in the rear housing?
Old Sep 14, 2006 | 08:17 AM
dieselrob's Avatar
Nobody out there wit this problem too.
Old Sep 14, 2006 | 11:26 AM
Greguw's Avatar
Are you having abs problems ...!
Greg
Old Sep 14, 2006 | 02:50 PM
dieselrob's Avatar
The abs light and my parking brake light are on when it happens but it doesnt affect them. Its just the speedo dont work. Every once and a while it jumps around. Wheni pull the little sender thing out the end of its all beat up.
Old Sep 14, 2006 | 04:37 PM
gmctd's Avatar
It's an oring seal - try using paper gasket to shim it up away from the reluctor ring 0.005" to 0.010".
When you shim it too far, the speedo will become erratic - pull the sensor and reduce the shim by 1/2.
Old Sep 15, 2006 | 10:29 AM
dieselrob's Avatar
Thanks for the tip ill try that this weekend and see what happens.
supr
18
May 21, 2007 09:29 AM
sjester
May 10, 2007 05:03 PM
tyssniffen
Feb 11, 2006 01:28 PM
Booost Almighty
Jan 1, 2006 01:41 PM
wildmann
Aug 14, 2005 07:15 PM
