SP Diesel Torque Converter Controller
Old Aug 29, 2013 | 02:04 PM
Numidian's Avatar
So my truck came with one of these in the center console... The harness for it is sitting on my steering column unplugged, because apparently the buttons on my cruise control are a little sticky and cause the controller to freak out.
I'm not so interested in having the whole automatic lockup. I'd just like to have a switch with locked and stock options.... I see no reason I could figure out the two wires I need from the SP Controller's harness and plug right into the existing wires I have instead of having to cut anything else up.
Now assuming my thoughts are correct, does anyone know which wires I need to tap into?
Old Aug 29, 2013 | 02:42 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
SP Diesel products are pure junk.....That is most likely why it is disconnected on your truck. They were so bad they were banned from the forum early on.......
I personally wouldn't hook that thing up on my truck.
Old Aug 29, 2013 | 02:48 PM
Numidian's Avatar
I'm not looking to use the controller anymore. I'd just like to wire up a switch to lock the converter. I'm guessing a single pole on off switch would do it, if I can figure out which two wires in the controller harness are hot and the TC solenoid? Or am I over simplifying?
Old Aug 29, 2013 | 02:51 PM
Admin Team Leader
Do a search for lock up switch, you should find just what you are seeking....just remember to turn it off when pulling up to a stop light
tigers72
May 14, 2009 06:19 PM
ChilliBowl
Oct 3, 2008 10:39 AM
Moobesor
Jul 26, 2008 08:44 PM
mainer
Jul 17, 2007 07:13 PM
