-   24 Valve Engine and Drivetrain (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/)
-   -   Soft pedal brake problem !!!! (https://www.dieseltruckresource.com/forums/24-valve-engine-drivetrain-89/soft-pedal-brake-problem-292357/)
dewclaw Jul 12, 2011 10:25 PM
Soft brake pedal problem !!!!
OK, so I started getting a soft brake pedal. I looked at all the wheel cyls and found the right rear a little wet . I changed it , bled the system , adjusted the rear brakes and I still had the soft brake pedal.
The pedal goes about half way down then starts braking. Im thinking , OK, 340000 miles , its master cyl time . I replaced that and did the super flush and brake cyl bleed on all four sides. Its still the same .
The pedal goes about half way down and then starts braking 'fairly' well. It does not slowly go to the floor ( which usually means bad master cyl.)
Im at a loss. So I start looking at the vacuum system . I replaced some hoses that were questionable.
Everything looks right ! wheel cyls dry, plenty of meat on the brakes, vacuum system in tact .
I noticed that the power steering pump lines run up into the brake booster area ...? I checked and topped off the fluid that was slightly low .
Where do I go next with this ?
Dump valve ?? I dont know what that thing does . Proportion valve ??
Can you guys / gals lend a hand ? I have searched the site but it doesnt describe my problem ...
Help ?
Thanks ,
Dew.
mini14 Jul 14, 2011 09:00 PM
sometimes the flex lines to the calipers or shoes look good from the outside, but will develop a bulge in them when the pedal is pushed.
