shifting problems
Old Dec 21, 2011 | 06:17 PM
patrick fedders's Avatar
shifting problems
i have a 01 2500 4x4 5.9 while im driving at about 55 plus and hit bumps in the road my truck will drop a gear or two and go back into overdrive then back and forth what could the problem be .i just had the tranny rebuilt too
Old Dec 21, 2011 | 07:03 PM
DodgeFreak's Avatar
this would go better in the 2nd gen forum but i'd start with grounding the tps and checking all grounds or adding more grounds, also sounds like a loose connection,
Old Dec 21, 2011 | 07:29 PM
i am having trouble with my truck when im driving in overdrive and hit a bump it will drop down and start going back and forth what could it be my truck is a 01 dodge 2500 4x4 24 valve and i also just had the tranny rebuilt
Old Dec 21, 2011 | 07:34 PM
might sound stupid but what is tps
Old Dec 21, 2011 | 08:39 PM
Onemoparnut's Avatar
Tps=throttle position sensor
Old Dec 21, 2011 | 09:54 PM
Greed 93's Avatar
That Truck has an apps sensor they are famous for going out. Could BC or some one move this to the right area.
Old Dec 22, 2011 | 07:06 PM
ok i checked all grounds and everything was tight i unplugged my chip i have a torch dog on it its weird i unplug it and it shifts perfect then it will go back to acting up so i just plug it back up so today when i checked everything i unplugged it again and now it is working fine . where do i locate the apps sensor to check it
Old Dec 23, 2011 | 03:50 AM
j-fox's Avatar
Also check the brake peddle!
If it is bouncing it will unlock the converter, which a lot of people think is OD!!
Hold your foot behind the peddle lifting it and go drive over the bumps.
Old Dec 23, 2011 | 12:00 PM
rickf's Avatar
If it works good without the chip then leave the sensor alone, there is nothing wrong with it. The problem is with the chip.
Old Dec 23, 2011 | 04:52 PM
i tried to go to work this morning and it wouldnt even go had to power only drive bout 30 mph so when i got home i reset the apps and took it off and unplugged it and wiped the connections off and went to drive it seems to be working fine now. now i guess time will tell if it is fixed .thanks for the help
Old Dec 23, 2011 | 04:55 PM
thanks i will try that and see
Old Dec 23, 2011 | 05:38 PM
rebal's Avatar
I have seen this over and over ,Just last week had a 99 in the shop doing the wierd shifting. the batteries were new optima red tops and connections looked clean. I cleaned the 4 bat, posts and the body grounds . problem is gone .
kellio
19
Mar 26, 2021 03:12 AM
DJ Turbo.
Oct 13, 2011 09:11 PM
Brendan
Oct 17, 2007 11:12 AM
98 Ram 24V
Dec 24, 2005 10:19 AM
CountryDiesel
Dec 1, 2003 10:24 AM
