RPM uptick when releasing clutch pedal
My motor revs slightly when I release the clutch pedal. The truck is a 2001.5,has about 178,000 miles on it, and has the 6 speed manual shift. Is this normal, or is there something fishy with the clutch or transmission?
Ted
Ted
Sounds fishy! Try finding if Catfish, carp, or bass.
Is this new as in just started/noticed? Check linkage to assure not being moved as engine torques up. You know the governor will override throttle and try to maintain RPM as load comes on!!! Even if you don't feather throttle taking of, the governor will give more fuel.
Thanks Dozer! LOL! I'll take the Bass, probably in the 15 lb. variety!
I have noticed this since purchasing the truck back last December with 172,000 on the ticker.
I will try your suggestions. Thanks!
Ted
Ted
Mine does that. You are just engaging the clutch disc and the gear sets in the trans when in neutral and adding drag to the engine which makes the governor kick up the rpms to keep the idle at the proper setting.
Kurt
Kurt
mine does it too.
I have a 98.5 (as you know if you looked at my sig.) and it does the same thing, i notice it more when i am really getting on it to get up to speed on the on ramp. But i also notice it when i have the engine lugged down around an idle just moving around in the driveway or parking lot. I have just asumed its normal cause all the diesels i have ever driven have done it(that were stick shift)
I also have a question...on the "insturment pannel light check" i get the little ''shift indicator'' light the comes on, however I never see the thing when i'm accually driving, just on the "light check"
Dave88LX
25
Jun 15, 2007 08:12 AM
