Replacing Wheel Studs On The Rear
I have a wheel stud with messed up threads on my 2001 with disk brakes on the rear. How hard and what all is involved in replacing that stud? Where can I get the stud?
anyone ?
I checked my service manual and you're going to need to remove the brake calipers, rotors, and adaptors then a stud removal tool is used to get it out (c-4150A). Installation is simpler- screw the stud in, put three washers on, screw the lug net in until the stud is pulled into the hub flange. Remove the lug nut and washers and reinstall brakes.
Sorry no experience nor practical advice here, but I hope this helps bro. |
I've never worked on a dodge rear end but I have yet to see a stud that would not come out with a hammer
where can i get the stud at?
Take the rear caliper off, beat the rotor off, hammer the studs out, hammer the new studs in, replace rotor, replace caliper. I got mine from o'reilly's.
I cant believe its that easy. Ill replace it tomorrow
Yup. I had to do mine after the monkey's at the tire store stripped 3 of them.
