refilling radiator after changing water pump
Old 11-01-2018, 09:18 PM
I just changed my water pump, and I could swear it only took about half as much coolant as I expected. I know there is some serious air bubbles in there...and since I'm obsessive-compulsive,..how can I get the air all out QUICKLY so I can quit worrying about it. For some reason I figured if I started it..it would immiediately suck the coolant out of the radiator and I could just fill it and be good with it. But apparently not,..and it's been so long since I've done this I can't remember. By the way,..I don't even think my original water pump was bad,..The o ring looked like it had shrunk a bit, or something...was really NO bigger than the slot where it went,..the new one was a bit bigger..which I'm sure was to exert pressure.
Puke is offline
Old 11-02-2018, 11:13 AM
I know our 12 valves have a valve you can open to bleed air on the Tstat housing, but I just looked through my 20001 service manual and it shows nothing like that, nor does it show any special bleeding procedure, so I would say you should be safe, just make sure your overflow container is full to the line and watch it.
patdaly is offline
Old 11-02-2018, 01:25 PM
AlpineRAM's Avatar
On my 98.5 it helps a lot if I get the front of the vehicle at least 3 feet up from horizontal.
If I don't do this I get an empty overflow each heat cycle until it's full.
AlpineRAM is offline
Old 11-03-2018, 11:56 AM
SIXSLUG's Avatar
You can pull the thermostat on an incline with the front of the truck uphill and get most of it. Make sure the heater core gets filled or you will get a nasty airlock. Running the heater on high doesn't make any difference either as it just adjusts the airway, not the flow of heated coolant....
SIXSLUG is offline
Old 11-04-2018, 03:48 AM
AlpineRAM's Avatar
I do not pull the t-stat, but keep the engine running until it reaches operating temperature so the t-stat opens.
Old 11-04-2018, 12:15 PM
SIXSLUG's Avatar
I only had an airlock one time in probably 4 or 5 flushes and refills. Seems it really helped to park it up a steeper incline to get all the air out....
SIXSLUG is offline
Old 11-06-2018, 11:34 AM
Mine I idled until the t-stat opened then I was good to go .
leeboy is offline
8liter
09-22-2012 10:19 AM
Silver R/T
08-26-2010 09:02 AM
BearKiller
01-13-2008 11:35 PM
jj3500
15
05-18-2007 10:54 PM
Tuckerdee
07-26-2006 04:26 PM
Quick Reply: refilling radiator after changing water pump
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
